Dears,
Is it possible to map an external volume to the container? For when you need to restart the container or other such activity, the user account settings remain valid.
I was able to map the plugins volume:
- ./var/lib/grafana/plugins:/var/lib/grafana/plugins
I’ve tried mapping so that user account data is persisted. But I did not succeed.
This my docker-compose.yml
version: ‘2’
services:
monitor:
restart: always
image: semantix/grafana
environment:
- GF_SECURITY_ADMIN_PASSWORD=password
- GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource,foursquare-clouderamanager-datasource
volumes:
- .:/home
networks:
- connection
ports:
- 3000:3000
networks:
connection:
You are using (private) semantix/grafana
Docker image, so only maintainer of this image knows the exact structure of the image. If it is based on official Grafana Docker image, then check official doc: http://docs.grafana.org/installation/docker/#grafana-container-with-persistent-storage-recommended
Thanks for the answer.
Yes, the image that is pointed in the docker-compose is a local image. But it was generated from a Dockerfile:
If anyone can help, I will be very grateful.
Dockerfile:
FROM debian:stretch-slim
ARG GRAFANA_URL=“https://s3-us-west-2.amazonaws.com/grafana-releases/master/grafana-latest.linux-x64.tar.gz”
ARG GF_UID=“472”
ARG GF_GID=“472”
ENV PATH=/usr/share/grafana/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
GF_PATHS_CONFIG="/etc/grafana/grafana.ini"
GF_PATHS_DATA="/var/lib/grafana"
GF_PATHS_HOME="/usr/share/grafana"
GF_PATHS_LOGS="/var/log/grafana"
GF_PATHS_PLUGINS="/var/lib/grafana/plugins"
GF_PATHS_PROVISIONING="/etc/grafana/provisioning"
RUN apt-get update && apt-get install -qq -y tar libfontconfig curl ca-certificates &&
mkdir -p “$GF_PATHS_HOME/.aws” &&
curl “$GRAFANA_URL” | tar xfvz - --strip-components=1 -C “$GF_PATHS_HOME” &&
apt-get autoremove -y &&
rm -rf /var/lib/apt/lists/* &&
groupadd -r -g $GF_GID grafana &&
useradd -r -u $GF_UID -g grafana grafana &&
mkdir -p “$GF_PATHS_PROVISIONING/datasources”
“$GF_PATHS_PROVISIONING/dashboards”
“$GF_PATHS_LOGS”
“$GF_PATHS_PLUGINS”
“$GF_PATHS_DATA” &&
cp “$GF_PATHS_HOME/conf/sample.ini” “$GF_PATHS_CONFIG” &&
cp “$GF_PATHS_HOME/conf/ldap.toml” /etc/grafana/ldap.toml &&
chown -R grafana:grafana “$GF_PATHS_DATA” “$GF_PATHS_HOME/.aws” “$GF_PATHS_LOGS” “$GF_PATHS_PLUGINS” &&
chmod 777 “$GF_PATHS_DATA” “$GF_PATHS_HOME/.aws” “$GF_PATHS_LOGS” “$GF_PATHS_PLUGINS”
EXPOSE 3000
COPY ./run.sh /run.sh
USER grafana
WORKDIR /
ENTRYPOINT [ “/run.sh” ]
It is mentioned in the doc: http://docs.grafana.org/installation/docker/#grafana-container-using-bind-mounts :
--volume "$PWD/data:/var/lib/grafana"
So use:
volumes:
- ./var/lib/grafana/:/var/lib/grafana
I recommend to read full doc - there is an important info about write permissions.
