Hi all,
I’m on Grafana 9.2 with a simple Pie Chart.
sum by (ProductVersionYear, ProductUpdateLevel)(sql_server_version{job="$job", ProductVersionYear=~"$sqlversion", exported_instance=~"$dbinstance"})
I would like to know if…is it possible sort legend by label?
From PromQL naturally is not possible… I tried from the grafana sorting but for this type of panel it seems that there is no setting that affects
Like this way:
2019 CU14
2019 CU8
2017 CU22
2017 CU10
2016 CU7
You might have to go with regex-ing your label so that, if all labels have CU, you just get the numeric value of the labels such as
201710
201914
Because what you have is string,
2019 C14 comes before 2019 C8
No, honestly it’s more logical that it’s sorted by value… I’ve thought about it. I put a table in another panel with the sorting to my liking. However I tried to see your indication, but I found it difficult to use the regexp … and to the logic of how to apply it.
thanks for your suggestion… regex101 it’s a great site, I use it too… but maybe I explained myself badly… also because I reply to these posts late at night and many times I’m tired, by the way, my problem wasn’t so much finding a pattern for the match but it was how I then had to insert it in the transformations in the grafana panel to change the sorting from value.
I’m using prometheus as data source… and data is a timeseries…
How do I manage the thing in the Grafana panel to have the desired sorting, therefore not following the numerical values there are by default?
This is my problem… 'cause there is always a series to choose in the sort combo selection, sorry if I was not clear before.
I have this pie chart and still wondering to group it into blue at the right side and red on the left side with that shown portion. Only for a beauty viz, sir.
As far as I know, the pie portion order is Descending Clock wise, but i am not so sure.
HI yosiasz,
I’m having the same problem as the author, and I want to sort the legend in order of Critical, Hight, Medium and Low, can you guide me in detail?
I mapped the high, medium, low and critical statuses to numeric values and sorted on that numeric value
select a.* from (
select 'A' metric ,84 value,'High' as status union
select 'B',10,'Low' union
select 'C',6,'Critical' union
select 'D',40,'Medium'
) a
join (
select 10 ste, 'High' as status union
select 20 ste, 'Medium' as status union
select 30 ste, 'Low' as status union
select 40 ste, 'Critical' as status
) ste on a.status = ste.status
order by ste.ste asc
HI yosiasz,
I use PostgreSQL as a data source, and here is my query that retrieves my data:
SELECT
CASE
WHEN point >90 AND point <=100 THEN ‘Critical’
WHEN point >70 AND point <=90 THEN ‘High’
WHEN point >50 AND point <=70 THEN ‘Medium’
WHEN point >= 0 AND point <= 50 THEN ‘Low’
END AS level,
COUNT(*) AS record_count
FROM object o
WHERE point >=0 and point <=100
GROUP BY level
