Hii all,
I think there is a problems with pie chart plugin, when we selected 1 Item, they change the value for other items
before
and after clicked “Ready”
this issue is the same results for Elasticsearch, Influx, MYSQL, Zabbix,… Data sources
Hope you can fix in next version
The community site is mostly for questions and your post is more of a bug report.
Please see opened issues at https://github.com/grafana/piechart-panel/issues and see if you find your problem listed. Otherwise I suggest that you create a new bug issue there describing your problem and including Grafana version and pie chart plugin versions.
Marcus
