Piechart-panel now showing up
Version 4.0.2
I’ve installed grafana pie chart. but it doesn’t show up in panel search filter. Only the default panels are visible.
Am I missing something? I want to use that pie for Zabbix.
Attached screenshot
grafana-cli install grafana-pie-chart-panel
It is installed in the default plugin directory.
In the logs:
t=2017-04-20T05:49:57+0000 lvl=info msg=“Registering plugin” logger=plugins name=Zabbix
t=2017-04-20T05:49:57+0000 lvl=info msg=“Registering plugin” logger=plugins name=“Zabbix Triggers”
t=2017-04-20T05:49:57+0000 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
Try reloading your browser window
Thanks, thought it would reflect just when I access a new page. Reloading page worked.
