9.2.3 -
In a general overview dashboard, I want to see if the data for the selected period of time exists or doesn’t. Not the value itself, but a True/False kind of time series graph.
So I have a couple of devices that connect sometimes and write data to influxDB, and I would like to have a graph just to see who was connected and when.
Note: I write the data myself.
It sounds like something quite simple, but I miss how it can be done.
Are you using InfluxQL or Flux?
I’m using Flux.
I can generate a 0/1 signal using map() and “No Value”, but as a time series it doesn’t look as nice as I would like.
Hmmmm…If you are looking for a graph showing On/Off, would something like this work? (shown in Influx…it would be prettier in Grafana).
