Hi Users and grafana team.
Since 4 months, i work on version 0.4.0.
I think this version is stable but before to pull for release, i need feedback and beta tester.
You can found it at
Documentation at
What’s news for this version :
[0.4.0 SNAPSHOT] - 2019-09-14
Added
Draw.io editor (Example)
- Open draw.io with dark theme for better rendering
- Display waiting screen when loading xml definition.
- Upgrading libraries
- mxGraph 4.0.4
- draw.io 11.2.8
- Graph definition
- Adding download function to download source by http on load. (Example)
- Metric
- Adding string support for state
- Zoom (issue #19) (Example)
- On the mouse pointer : Ctrl + Mouse
- Hold right button to move diagram.
- double click on shape to zoom on.
- Escape key to restore.
- Tooltip/popup support (Example)
- Grafana style css and date
- Adding metrics with color according levels
- Adding colors on metrics in tooltip
- Adding date of change
- Adding label input for metric
- Variables/templates support, accept variable like ${} (Example)
- In xml definition
- In text mapping when type in sring for “Range to text” and “Value to text”
- In link ovewrite
- full shapes from draw.io included (Examples)
- Some optimizations
Fixed
- Optimization when refresh/render (issue #15)
- No decimal fixed when 0 (issue #23)
- Text substring and color (issues #29)
BR
Arnaud
