mata
April 23, 2020, 10:34am
1
I install plugin with
sudo grafana-cli plugins install grafana-worldmap-panel
restart service with
sudo /opt/bitnami/ctlscript.sh restart grafana
all is ok
plugin is installed correctly but I can’t see it in the dashbord
can someone help me?
Tanks
You are installing grafana as root, grafan might be running under different user name, did you check the plugindir permission? Check the plugins dir permission
I have the same problem.
I can see worldmap in plugins inside the grafana interface but cannot see the dashboard
I use : sudo docker exec -it c449b31d /bin/bash
and found that plugins in /var/lib/grafana/plugins directory, with user grafana/grafana
seems no problem in directory permission
any help is appreciated
I got that resolved. thanks
