Hello. I’m trying to make a plug-in panels. I want for my plug-in panels to perform unique queries (read/write) to the data source. And I would like to ask, is it possible to use the data source class QueryCtrl in the plug-in panels?
No, you only get access to the datasource abstraction via the datasourceSrv get method
Thanks for the feedback. I also wanted to clarify: do I understand correctly if I want to make a unique query to the data source in my “panel” plugin, then I can use the “issueQueries(datasource)” method in which I can change the query data and send a request to the data source, like “datasource.query(metricsQuery)”, where “metricsQuery” is the unique requested data.
just inherit from MetricsPanelCtrl and subscribe to data received event https://github.com/grafana/grafana/blob/master/public/app/plugins/panel/singlestat/module.ts#L81
This is understandable, I meant about a write query. I want to realize the ability to make comments that are written to the database
write query? there is no such thing
Hi how do I call the simpleJson data source from my panel plugin
