I have forked the clock plugin.
I can build it, and use it in the latest Grafana with a new name.
When I change or try to add to the CSS file nothing happens.
I am following these steps:
- edit css file and save.
- run grunt in topmost directory, get no errors
- check dist directory- files changed
- restart grafana daemon
- reload browser page at clock plugin
no change
What am I doing wrong?
Could it be a chrome caching problem? Have you tried opening Chrome Dev Tools and doing a hard reload (you can also click and hold on the refresh button in Chrome to do an “Empty Cache and Hard Reload”.
Thanks for your quick response. It was a good suggestion, but the real problem was a name-space collision when I did not rename clock-panel.css. Using the old clock and the new clock together on a dashboard meant the original css over-rode the new one.
2nd reply-
Daniel heres what I found today, if you can offer guidance, it would be much appreciated…
based on clock plugin, forked and building on server in plugins directory
never used React or Angular and quite rusty with JS-HTML-CSS, so I may not ‘get it’
changes made to clock-panel.css ( panel-title-text for example) change ALL plugins. This was not expected!
changes made to module.html (in-line styles) change only the clock plugin - this is expected
changing the panel title text size breaks react-grid-item: the re-sizable component fails to size itself to match the visible rectangle correctly. The result is panels that overlap.
