Problem in Logging in
Hi there,
I have tried logging in using the admin as username & password.
But it is showing as incorrect.
Hope you can help
Thanks,
Ram.
Hi!
How did you set up your Grafana instance? Are you using Docker or a binary install?
Are you sure your database is brand new?
Do you have any logs on the browser and / or the server that add information?
Im using docker.
My database is new.
I don’t think there’s any such logs
