GitHub Issue: Promtail does not increase positions, but set positions zero after a few hours. And then not report logs anymore. · Issue #9864 · grafana/loki · GitHub
Environment
- kubernetes 1.15, kubeadm, ubuntu 22.04
- CONTAINER-RUNTIME: docker
- loki 2.8.2, promtail 2.8.2
- no log rotation
More information
- loki-stack helm charts values.yaml
loki:
image:
registry: docker.io
repository: grafana/loki
tag: 2.8.2
pullPolicy: IfNotPresent
config:
auth_enabled: false
compactor:
shared_store: filesystem
working_directory: /data/loki/boltdb-shipper-compactor
ingester:
lifecycler:
ring:
kvstore:
store: inmemory
replication_factor: 1
wal:
dir: /data/loki/wal
limits_config:
enforce_metric_name: false
ingestion_burst_size_mb: 100
ingestion_rate_mb: 50
per_stream_rate_limit: 5MB
per_stream_rate_limit_burst: 20MB
reject_old_samples: true
reject_old_samples_max_age: 168h
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: filesystem
schema: v11
store: boltdb-shipper
server:
grpc_listen_port: 9095
http_listen_port: 3100
storage_config:
boltdb_shipper:
active_index_directory: /data/loki/boltdb-shipper-active
cache_location: /data/loki/boltdb-shipper-cache
cache_ttl: 24h
filesystem:
directory: /data/loki/chunks
promtail:
image:
registry: docker.io
repository: grafana/promtail
tag: 2.8.2
config:
file: |
server:
http_listen_port: 3101
log_level: info
clients:
- url: http://loki:3100/loki/api/v1/push
positions:
filename: /run/promtail/positions.yaml
scrape_configs:
- job_name: kubernetes-pod-label-app
pipeline_stages:
- docker: {}
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels:
- __meta_kubernetes_pod_label_app
regex: ''
action: drop
- regex: __meta_kubernetes_pod_label_(.+)
action: labelmap
- source_labels:
- __meta_kubernetes_pod_node_name
target_label: __host__
- source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- source_labels:
- __meta_kubernetes_pod_name
target_label: pod
- source_labels:
- __meta_kubernetes_pod_container_name
target_label: container
- source_labels:
separator: /
target_label: job
- source_labels:
- __meta_kubernetes_pod_uid
separator: /
replacement: /var/log/pods/*$1/*.log
target_label: __path__
"registry-mirrors": ["https://docker.mirrors.ustc.edu.cn"]
positions:
/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log: "0"
> ll /var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log
lrwxrwxrwx 1 root root 165 Jun 30 17:17 /var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log -> /var/lib/docker/containers/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c-json.log
> ll -h /var/lib/docker/containers/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c-json.log
-rw-r----- 1 root root 295M Jul 5 18:51 /var/lib/docker/containers/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c/103f6f04fd7a429b7453dc54b901ae2d468cfcf6243a0df60073b8ac1d5b633c-json.log
level=info ts=2023-07-05T10:15:53.083081825Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181553 op=CREATE
level=info ts=2023-07-05T10:15:53.083185919Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log op=CREATE
level=info ts=2023-07-05T10:16:03.114822749Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181603 op=CREATE
level=info ts=2023-07-05T10:16:03.114948545Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log op=CREATE
level=info ts=2023-07-05T10:16:13.144539294Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181613 op=CREATE
level=info ts=2023-07-05T10:16:13.144664458Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log op=CREATE
level=info ts=2023-07-05T10:16:23.174391523Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181623 op=CREATE
ts=2023-07-05T10:16:23.174424625Z caller=log.go:168 level=info msg="Re-opening moved/deleted file /var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log ..."
ts=2023-07-05T10:16:23.174452889Z caller=log.go:168 level=info msg="Waiting for /var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log to appear..."
level=info ts=2023-07-05T10:16:23.174535974Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log op=CREATE
level=info ts=2023-07-05T10:16:33.205825404Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181633 op=CREATE
level=info ts=2023-07-05T10:16:33.205986155Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log op=CREATE
level=info ts=2023-07-05T10:16:43.237606654Z caller=filetargetmanager.go:179 msg="received file watcher event" name=/var/log/pods/renderelf_renderelf-frontend-bf89b465c-qwg79_6379d476-a439-499f-99d8-4a1c442349e9/renderelf-frontend/0.log.20230705-181643 op=CREATE
system
Closed
3
