basically I am trying to ship logs from promtail agent to loki
though everthing up and running loki and promtail
for some reason my promtail agent not able to push the logs to the loki
throwing me the following error
level=error ts=2022-02-10T20:01:07.141341734Z caller=client.go:360 component=client host=ams-loki:3100 msg=“final error sending batch” status=404 error=“server returned HTTP status 404 Not Found (404): 404 page not found”
Could you please help?
b0b
February 14, 2022, 3:58pm
2
Hi @mramuthan ,
your not giving us a whole lot to go by
Short answer, Promtail can’t find host=ams-loki:3100
How have you deployed Loki and Promtail? Based on the host name it seems like a container platform of some sort?
Here is the context, I am using the following helm charts to install loki and promtail on a k8 cluster:
grafana/loki (chart version: 2.9.1 , App version: v2.4.2 )
grafana/promtail (chart version: 3.11.0 , App version: 2.4.2 )
These charts are coming from Grafana Community Kubernetes Helm Charts | helm-charts
And following is the final configuration for the promtail agent
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_port: 3101
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 9095
grpc_listen_conn_limit: 0
http_tls_config:
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 5m0s
grpc_server_ping_without_stream_allowed: false
log_format: logfmt
log_level: info
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
http_path_prefix: ""
external_url: ""
health_check_target: null
disable: false
client:
url: http://loki:3100/api/v1/push
batchwait: 1s
batchsize: 1048576
follow_redirects: false
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
stream_lag_labels: filename
clients:
- url: http://loki:3100/api/v1/push
batchwait: 1s
batchsize: 1048576
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
positions:
sync_period: 10s
filename: /run/promtail/positions.yaml
ignore_invalid_yaml: false
scrape_configs:
- job_name: kubernetes-pods
pipeline_stages:
- cri: {}
relabel_configs:
- source_labels: [__meta_kubernetes_pod_controller_name]
separator: ;
regex: ([0-9a-z-.]+?)(-[0-9a-f]{8,10})?
target_label: __tmp_controller_name
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_label_app_kubernetes_io_name, __meta_kubernetes_pod_label_app,
__tmp_controller_name, __meta_kubernetes_pod_name]
separator: ;
regex: ^;*([^;]+)(;.*)?$
target_label: app
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_label_app_kubernetes_io_component, __meta_kubernetes_pod_label_component]
separator: ;
target_label: component
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_node_name]
separator: ;
regex: (.*)
target_label: node_name
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_namespace]
separator: ;
regex: (.*)
target_label: namespace
replacement: $1
action: replace
- source_labels: [namespace, app]
separator: /
regex: (.*)
target_label: job
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_name]
separator: ;
regex: (.*)
target_label: pod
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_container_name]
separator: ;
regex: (.*)
target_label: container
replacement: $1
action: replace
- source_labels: [__meta_kubernetes_pod_uid, __meta_kubernetes_pod_container_name]
separator: /
regex: (.*)
target_label: __path__
replacement: /var/log/pods/*$1/*.log
action: replace
- source_labels: [__meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash,
__meta_kubernetes_pod_annotation_kubernetes_io_config_hash, __meta_kubernetes_pod_container_name]
separator: /
regex: true/(.*)
action: replace
static_configs: []
target_config:
sync_period: 10s
stdin: false
I verified the loki is up and running by going to the URL http://loki:3100/ready
but the promtail agent not able to reach out to it and showing the following error
level=error ts=2022-02-10T20:01:07.141341734Z caller=client.go:360 component=client host=loki:3100 msg=“final error sending batch” status=404 error=“server returned HTTP status 404 Not Found (404): 404 page not found”
b0b
February 15, 2022, 8:23am
4
Looking at my own agent config I see I use this url
http://loki.loki:3100/loki/api/v1/push
I have Loki running in a separate namespace, so the service name is loki.loki
. The difference I wanted to highlight is the /loki
after the port which you do not have in your url
. It is also in the Promtail client config comment
So I would try adding that to the url
and see if that fixes the issue.
system
Closed
February 15, 2023, 8:23am
5
