I am trying to configure a secure architecture where each of my ~ 10 servers can send their logs to my central monitoring architecture.
From what I understood, so far my best option is leveraging the promtail --> promtail
authentication to have something like this:
Server_{1..n}(promtail) --> Server_monitoring(promtail --> loki --> grafana);
Even more precisely, everything running on Server_monitoring
is authenticated through OAuth2 (using gitlab.com as an identity provider), configure with caddy
Server_{1..n}(promtail) --> Server_monitoring( caddy+gitlab_oauth2 --> (promtail --> loki --> grafana)) ;
I found the clients:
documentation Configuration | Grafana Loki documentation and tried to adapt it:
clients:
- url: https://protmail.server_monitoring.domain/loki/api/v1/push
oauth2:
client_id: 'client_id_obfuscated'
client_secret: 'client_secret_obfuscated'
#scopes: "openid"
token_url: https://gitlab.com/oauth/token
… but it doesn’t propagate anything, nor does it prints any error in the logs:
My full (oauth Id obfuscated) configuration is the following for the client (server_n
) promtail:
server:
http_listen_address: 0.0.0.0
http_listen_port: 9080
positions:
filename: /tmp/positions.yaml
clients:
oauth2:
#scopes: "openid"
scrape_configs:
- job_name: containers
static_configs:
- targets:
- localhost
labels:
job: containerlogs
__path__: /var/lib/docker/containers/*/*log
pipeline_stages:
- json:
expressions:
log: log
stream: stream
time: time
tag: attrs.tag
compose_project: attrs."com.docker.compose.project"
compose_service: attrs."com.docker.compose.service"
stack_name: attrs."com.docker.stack.namespace"
swarm_service_name: attrs."com.docker.swarm.service.name"
swarm_task_name: attrs."com.docker.swarm.task.name"
- regex:
expression: "^/var/lib/docker/containers/(?P<container_id>.{12}).+/.+-json.log$"
source: filename
- timestamp:
format: RFC3339Nano
source: time
- labels:
stream:
container_id:
tag:
compose_project:
compose_service:
stack_name:
swarm_service_name:
swarm_task_name:
- output:
source: log
and I’m launching promtail through docker-compose.yml:
services:
promtail:
image: grafana/promtail:latest
container_name: promtail
#<<: *logging
volumes:
- /var/log:/var/log
- ./promtail:/etc/promtail/
command: -config.file=/etc/promtail/promtail-config.yaml -print-config-stderr
restart: always
The only logs I get are the following:
$ sudo docker-compose -f docker-compose.yml --env-file env.ud1 up --no-deps -d --force-recreate promtail && make logsf-promtail
[+] Running 1/1
⠿ Container promtail Started 1.7s
sudo docker-compose -f docker-compose.yml --env-file env.ud1 logs --tail=500 -tf promtail
promtail | 2022-12-27T21:47:48.850524030Z ---
promtail | 2022-12-27T21:47:48.850553946Z # Loki Config
promtail | 2022-12-27T21:47:48.850562242Z # (version=2.7.1, branch=HEAD, revision=e0af1cc8a)
promtail | 2022-12-27T21:47:48.850568784Z server:
promtail | 2022-12-27T21:47:48.850580065Z http_listen_network: tcp
promtail | 2022-12-27T21:47:48.850584313Z http_listen_address: 0.0.0.0
promtail | 2022-12-27T21:47:48.850588240Z http_listen_port: 9080
promtail | 2022-12-27T21:47:48.850591847Z http_listen_conn_limit: 0
promtail | 2022-12-27T21:47:48.850600744Z grpc_listen_network: tcp
promtail | 2022-12-27T21:47:48.850604832Z grpc_listen_address: ""
promtail | 2022-12-27T21:47:48.850608669Z grpc_listen_port: 9095
promtail | 2022-12-27T21:47:48.850612586Z grpc_listen_conn_limit: 0
promtail | 2022-12-27T21:47:48.850620521Z tls_cipher_suites: ""
promtail | 2022-12-27T21:47:48.850624839Z tls_min_version: ""
promtail | 2022-12-27T21:47:48.850628496Z http_tls_config:
promtail | 2022-12-27T21:47:48.850635449Z cert_file: ""
promtail | 2022-12-27T21:47:48.850639076Z key_file: ""
promtail | 2022-12-27T21:47:48.850643063Z client_auth_type: ""
promtail | 2022-12-27T21:47:48.850646510Z client_ca_file: ""
promtail | 2022-12-27T21:47:48.850653593Z grpc_tls_config:
promtail | 2022-12-27T21:47:48.850657721Z cert_file: ""
promtail | 2022-12-27T21:47:48.850661288Z key_file: ""
promtail | 2022-12-27T21:47:48.850664864Z client_auth_type: ""
promtail | 2022-12-27T21:47:48.850672379Z client_ca_file: ""
promtail | 2022-12-27T21:47:48.850676136Z register_instrumentation: true
promtail | 2022-12-27T21:47:48.850679642Z graceful_shutdown_timeout: 30s
promtail | 2022-12-27T21:47:48.850683299Z http_server_read_timeout: 30s
promtail | 2022-12-27T21:47:48.850690893Z http_server_write_timeout: 30s
promtail | 2022-12-27T21:47:48.850694901Z http_server_idle_timeout: 2m0s
promtail | 2022-12-27T21:47:48.850699860Z grpc_server_max_recv_msg_size: 4194304
promtail | 2022-12-27T21:47:48.850707144Z grpc_server_max_send_msg_size: 4194304
promtail | 2022-12-27T21:47:48.850711151Z grpc_server_max_concurrent_streams: 100
promtail | 2022-12-27T21:47:48.850714678Z grpc_server_max_connection_idle: 2562047h47m16.854775807s
promtail | 2022-12-27T21:47:48.850718886Z grpc_server_max_connection_age: 2562047h47m16.854775807s
promtail | 2022-12-27T21:47:48.850725949Z grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
promtail | 2022-12-27T21:47:48.850729626Z grpc_server_keepalive_time: 2h0m0s
promtail | 2022-12-27T21:47:48.850733674Z grpc_server_keepalive_timeout: 20s
promtail | 2022-12-27T21:47:48.850737892Z grpc_server_min_time_between_pings: 5m0s
promtail | 2022-12-27T21:47:48.850744694Z grpc_server_ping_without_stream_allowed: false
promtail | 2022-12-27T21:47:48.850748962Z log_format: logfmt
promtail | 2022-12-27T21:47:48.850752349Z log_level: info
promtail | 2022-12-27T21:47:48.850759923Z log_source_ips_enabled: false
promtail | 2022-12-27T21:47:48.850764111Z log_source_ips_header: ""
promtail | 2022-12-27T21:47:48.850767878Z log_source_ips_regex: ""
promtail | 2022-12-27T21:47:48.850772076Z log_request_at_info_level_enabled: false
promtail | 2022-12-27T21:47:48.850779249Z http_path_prefix: ""
promtail | 2022-12-27T21:47:48.850783107Z external_url: ""
promtail | 2022-12-27T21:47:48.850786984Z health_check_target: null
promtail | 2022-12-27T21:47:48.850791222Z disable: false
promtail | 2022-12-27T21:47:48.850802453Z enable_runtime_reload: false
promtail | 2022-12-27T21:47:48.850806992Z client:
promtail | 2022-12-27T21:47:48.850810568Z url: ""
promtail | 2022-12-27T21:47:48.850813925Z batchwait: 1s
promtail | 2022-12-27T21:47:48.850821539Z batchsize: 1048576
promtail | 2022-12-27T21:47:48.850825597Z follow_redirects: false
promtail | 2022-12-27T21:47:48.850837379Z enable_http2: false
promtail | 2022-12-27T21:47:48.850844833Z backoff_config:
promtail | 2022-12-27T21:47:48.850848620Z min_period: 500ms
promtail | 2022-12-27T21:47:48.850852156Z max_period: 5m0s
promtail | 2022-12-27T21:47:48.850856034Z max_retries: 10
promtail | 2022-12-27T21:47:48.850863518Z timeout: 10s
promtail | 2022-12-27T21:47:48.850867786Z tenant_id: ""
promtail | 2022-12-27T21:47:48.850871613Z stream_lag_labels: ""
promtail | 2022-12-27T21:47:48.850875360Z clients:
promtail | 2022-12-27T21:47:48.850883105Z - url: https://promtail.server_monitoring.domain/loki/api/v1/push
promtail | 2022-12-27T21:47:48.850887072Z batchwait: 1s
promtail | 2022-12-27T21:47:48.850890579Z batchsize: 1048576
promtail | 2022-12-27T21:47:48.850894296Z oauth2:
promtail | 2022-12-27T21:47:48.850901379Z client_id: <obfuscated>
promtail | 2022-12-27T21:47:48.850905467Z client_secret: <secret>
promtail | 2022-12-27T21:47:48.850909805Z client_secret_file: ""
promtail | 2022-12-27T21:47:48.850917239Z token_url: https://gitlab.com/oauth/token
promtail | 2022-12-27T21:47:48.850921186Z follow_redirects: false
promtail | 2022-12-27T21:47:48.850925955Z enable_http2: false
promtail | 2022-12-27T21:47:48.850929752Z backoff_config:
promtail | 2022-12-27T21:47:48.850936976Z min_period: 500ms
promtail | 2022-12-27T21:47:48.850940803Z max_period: 5m0s
promtail | 2022-12-27T21:47:48.850944770Z max_retries: 10
promtail | 2022-12-27T21:47:48.850948758Z timeout: 10s
promtail | 2022-12-27T21:47:48.850955791Z tenant_id: ""
promtail | 2022-12-27T21:47:48.850959618Z stream_lag_labels: ""
promtail | 2022-12-27T21:47:48.850963716Z positions:
promtail | 2022-12-27T21:47:48.850967704Z sync_period: 10s
promtail | 2022-12-27T21:47:48.850975148Z filename: /tmp/positions.yaml
promtail | 2022-12-27T21:47:48.850979135Z ignore_invalid_yaml: false
promtail | 2022-12-27T21:47:48.850982952Z scrape_configs:
promtail | 2022-12-27T21:47:48.850989765Z - job_name: containers
promtail | 2022-12-27T21:47:48.850993462Z pipeline_stages:
promtail | 2022-12-27T21:47:48.850996888Z - json:
promtail | 2022-12-27T21:47:48.851000946Z expressions:
promtail | 2022-12-27T21:47:48.851007949Z compose_project: attrs."com.docker.compose.project"
promtail | 2022-12-27T21:47:48.851012157Z compose_service: attrs."com.docker.compose.service"
promtail | 2022-12-27T21:47:48.851015884Z log: log
promtail | 2022-12-27T21:47:48.851019791Z stack_name: attrs."com.docker.stack.namespace"
promtail | 2022-12-27T21:47:48.851027686Z stream: stream
promtail | 2022-12-27T21:47:48.851031393Z swarm_service_name: attrs."com.docker.swarm.service.name"
promtail | 2022-12-27T21:47:48.851035180Z swarm_task_name: attrs."com.docker.swarm.task.name"
promtail | 2022-12-27T21:47:48.851042574Z tag: attrs.tag
promtail | 2022-12-27T21:47:48.851046261Z time: time
promtail | 2022-12-27T21:47:48.851049928Z - regex:
promtail | 2022-12-27T21:47:48.851053585Z expression: ^/var/lib/docker/containers/(?P<container_id>.{12}).+/.+-json.log$
promtail | 2022-12-27T21:47:48.851061600Z source: filename
promtail | 2022-12-27T21:47:48.851065177Z - timestamp:
promtail | 2022-12-27T21:47:48.851069194Z format: RFC3339Nano
promtail | 2022-12-27T21:47:48.851073172Z source: time
promtail | 2022-12-27T21:47:48.851081568Z - labels:
promtail | 2022-12-27T21:47:48.851085435Z compose_project: null
promtail | 2022-12-27T21:47:48.851089352Z compose_service: null
promtail | 2022-12-27T21:47:48.851092869Z container_id: null
promtail | 2022-12-27T21:47:48.851099782Z stack_name: null
promtail | 2022-12-27T21:47:48.851103849Z stream: null
promtail | 2022-12-27T21:47:48.851107226Z swarm_service_name: null
promtail | 2022-12-27T21:47:48.851114379Z swarm_task_name: null
promtail | 2022-12-27T21:47:48.851118277Z tag: null
promtail | 2022-12-27T21:47:48.851121623Z - output:
promtail | 2022-12-27T21:47:48.851125280Z source: log
promtail | 2022-12-27T21:47:48.851132644Z static_configs:
promtail | 2022-12-27T21:47:48.851136210Z - targets:
promtail | 2022-12-27T21:47:48.851139667Z - localhost
promtail | 2022-12-27T21:47:48.851143414Z labels:
promtail | 2022-12-27T21:47:48.851151329Z __path__: /var/lib/docker/containers/*/*log
promtail | 2022-12-27T21:47:48.851155026Z job: containerlogs
promtail | 2022-12-27T21:47:48.851158793Z target_config:
promtail | 2022-12-27T21:47:48.851162179Z sync_period: 10s
promtail | 2022-12-27T21:47:48.851169313Z stdin: false
promtail | 2022-12-27T21:47:48.851173180Z limits_config:
promtail | 2022-12-27T21:47:48.851176767Z readline_rate: 10000
promtail | 2022-12-27T21:47:48.851184221Z readline_burst: 10000
promtail | 2022-12-27T21:47:48.851187978Z readline_rate_drop: true
promtail | 2022-12-27T21:47:48.851191785Z max_streams: 0
promtail | 2022-12-27T21:47:48.851195802Z tracing:
promtail | 2022-12-27T21:47:48.851203527Z enabled: true
promtail | 2022-12-27T21:47:48.851207444Z
promtail | 2022-12-27T21:47:48.851211041Z
promtail | 2022-12-27T21:47:48.949321575Z level=info ts=2022-12-27T21:47:48.85189134Z caller=promtail.go:123 msg="Reloading configuration file" md5sum=99229b92ee1e3994a6aad5511810b9a9
promtail | 2022-12-27T21:47:48.949354296Z level=info ts=2022-12-27T21:47:48.853190261Z caller=server.go:323 http=[::]:9080 grpc=[::]:9095 msg="server listening on addresses"
promtail | 2022-12-27T21:47:48.949359406Z level=info ts=2022-12-27T21:47:48.853319033Z caller=main.go:171 msg="Starting Promtail" version="(version=2.7.1, branch=HEAD, revision=e0af1cc8a)"
promtail | 2022-12-27T21:47:48.949362231Z level=warn ts=2022-12-27T21:47:48.853335273Z caller=promtail.go:220 msg="enable watchConfig"
promtail | 2022-12-27T21:47:53.949498530Z level=info ts=2022-12-27T21:47:53.853343061Z caller=filetargetmanager.go:352 msg="Adding target" key="/var/lib/docker/containers/*/*log:{job=\"containerlogs\"}"
Any suggestion on how to make this work would be greatly appreciated !
