Hello Community,
I have a legacy system which generates enormous amounts of logs. In order to get this system attached to Loki my idea is to have a configuration that drops anything per default except lines that match a Regex ruleset. The only thing I found is the drop Stage but this is the opposite I want. Is my use case feasible with Promtail? If not, which log-shipper may I use for?
Thanks in advance.
Hey @royboerner
Can you invert your regex?
Have you looked at the match stage?
judas
September 23, 2021, 1:44pm
4
The drop stage should work for your usecase. define a tag that gets filled when your regex hits and afterwards drop all lines where this tag is empty.
Thank you guys.
I can now share a working configuration.
server:
http_listen_port: 9080
grpc_listen_port: 0
#log_level: debug
positions:
filename: /tmp/promtail-positions.yaml
client:
url: http://vm061:3100/loki/api/v1/push
scrape_configs:
- job_name: mes
static_configs:
- labels:
# A `job` label is fairly standard in prometheus and useful for linking metrics and logs
job: mes
# A `host` label will help identify logs from this machine vs others
host: ${HOSTNAME:localhost}
# The path matching uses a third party library: https://github.com/bmatcuk/doublestar
__path__: /app/300works/log/MES_PROD.{FABsrv,TRANSsrv,EDCsrv,EPRsrv,LISTsrv,OCAPsrv,QUERYsrv,RTLsrv}_log
pipeline_stages:
- match:
selector: '{job="mes"}'
stages:
- regex:
expression: '^(?P<timestmap>\d{2}\/\d{2}\/\d{2} \d{2}:\d{2}:\d{2}.\d{2}).*$'
- timestamp:
source: timestmap
# 09/21/21 13:09:38.73
format: '01/02/06 15:04:05.999'
- regex:
expression: 'fwsrvExecServerRule:start executing rule (?P<rule_name>.*)$'
- labels:
rule_name:
- regex:
expression: 'FwTransaction::storeIt:(?P<rule_name>[^\s]+)'
- labels:
rule_name:
- regex:
expression: 'FwTransaction::doIt:(?P<rule_name>[^\s]+)'
- labels:
rule_name:
- regex:
expression: 'FwDbStmtOracle::execute:(?P<rule_name>[^\s]+)'
- labels:
rule_name:
- match:
# drop anything that has no rule_name label
selector: '{job="mes", rule_name!~"(.+)"}'
action: drop
system
Closed
October 11, 2022, 12:39pm
6
