I am setting up a Grafana instance that will have multiple organizations (SaaS, Dev, DevOps) and want to us provisioning files. each org will basically have the same data sources. I have tried using the same yaml file multiple times (different file name, and different orgID) and I tried having one file with multiple definitions in it but in each case the provisioning is only applied to org 1. When I go into the datasources for org 1 I can see the banner notifying me to “contact your server admin” but for org 2 and 3 they are still free form.
Some examples:
$ more site1.yaml
# # config file version
apiVersion: 1
# list of datasources that should be deleted from the database
deleteDatasources:
datasources:
- &main_datasource
isDefault: false
access: proxy
type: prometheus
org_id: 1
url: http://<<myserver>>:9090
editable: false
version: 2
- <<: *main_datasource
org_id: 2
org_id: 3
And I tried:
$ more site2-tsdb.yaml
apiVersion: 1
deleteDatasources:
datasources:
- name: site2-TSDB
isDefault: false
access: proxy
type: prometheus
org_id: 1
url: http://<<myserver>>:8428
editable: false
- name: site2-TSDB
isDefault: false
access: proxy
type: prometheus
org_id: 2
editable: false
- name: site2-TSDB
isDefault: false
access: proxy
type: prometheus
org_id: 3
editable: false
There are no errors in the logs.
Thoughts?
