- v8.0.0 (41f0542c1e)
- Assign value to dashboard variable by getting LENGTH of value of another variable
- As a query variable. Following query:
SELECT LENGTH(${location_ids:sqlstring}); // even trying the following gives None as value SELECT LENGTH('grafana');
What happened?
- This query was working just fine until I upgraded to
Grafana 8.0
- Work as expected
- No
- No. All of my errors originate from not being able to parse LENGTH of an already existing dashboard variable
Did you follow any online instructions? If so, what is the URL?
- Not applicable as Dashboard was working just fine previously under
Grafana 7.X
Hi @pupdogg
Have you tried toggling table view
in the query editor? The SQL datasources changes how they render data frames in g8, so some queries will need to be adjusted.
here is a note about those changes:
