Query with counter
Hi Expert,
I am doing a simple query, with a record or row counter, when I try to graph it does not take the correct field to show as Y, how can I do it or what is my error?
The value of the result is correct, but the column that is in yellow, how do I make it to be placed as Legend?
welcome to the :grafana: forum, @angelmendozaosuna
can you please follow these steps to share your raw unformatted data? That way, the community can try and mock up your problem as static CSV data :+1:
Hi Mattabrams
In the session you indicate, the data is displayed correctly, but when you draw the graph, the name of the field is displayed.
