i have two smokeping-exporters scraped by prometheus whose values should be displayed as a graph. The prometheus feeds its values to a Victoriametrics Database which can be queried with PromQL and is added as a Prometheus datasource in Grafana.
Each exporter should be defined as an environment, and has several targets. Therefore i have defined two variables in the according grafana dashboard:
- environment:
label_values(ping_rtt_mean_ms, environment)
- target:
label_values(ping_rtt_mean_ms{environment=~"$environment"}, target)
Both variables show preview values, however, the target only shows preview values like it would have if the alphabetically first value of environment would have been chosen.
So i have created a panel with a very simple query:
ping_rtt_mean_ms{environment="$environment", target="$target"}
- which is working fine. But now, the problems arise:
When i select one environment, i want to see the results for multiple targets. I have configured the panel to have a repeat by variable “target”, and set the variable target to multi-value. As soon as i enable the multi-value flag for “target”, the panel does not show any value. However, the drop-down value for the variable is populated with the proper values, and if i select more than one target, the panel goes into repeating mode.
So, i think, something with my query inside the panel is not fully correct. Since this is my first time with definint dependent variables, i am seeking for your help, since i cannot solve this on my own. Where is my error?
