Questions about the default Kubernetes Pod Metrics dashboard
I downloaded the default kubernetes Pod Metrics dashboard as below,
https://grafana.com/dashboards/747
But I found that some metrics as below used in the dashboard do not exist in prometheus. What did I miss?
container_memory_working_set_bytes
container_cpu_usage_seconds_total
container_network_receive_bytes_total
Some related information is as below,
prometheus version: v2.0.0
grafana version: v4.6.2
kube-state-metrics: quay.io/coreos/kube-state-metrics:v1.1.0
addon-resizer: Google Cloud console
OS: Oracle Linux 7.3
Thanks.
I can see that the referred dashboard haven’t been updated since late 2016. So maybe something have changed in the kube-state-metrics. Maybe you can submit a question on the kube-state-metrics github repository,
Marcus
Yes, you are right. Thanks.
