Hello and welcome!
We will be making it easier to exclude undesired metrics as part of #1321 but for now, you might consider using Trends along with some code that keeps track of whether the test is ramping up or down.
Here’s a working example, using some code from SO to help with the date comparison:
import { sleep } from 'k6';
import http from 'k6/http';
import { Trend } from 'k6/metrics';
let rampingUp = new Trend('http_req_duration_ramping');
let steadyState = new Trend('http_req_duration_steady');
export let options = {
stages: [
{ target: 1, duration: '15s' }, // ramp-up
{ target: 1, duration: '15s' }, // steady-state
{ target: 0, duration: '15s' } // ramp-down
// use setup to calculate at which point (date + time) the test will be fully ramped up
export function setup() {
const rampupDt = dateAdd(new Date(), 'second', 15);
const rampdownDt = dateAdd(rampupDt, 'second', 15);
console.log('Test will be fully ramped up at ' + rampupDt.toString() + ' and ramping down at ' + rampdownDt.toString());
return { rampupDt: rampupDt, rampdownDt: rampdownDt }; // setup() needs to return an object
export default function(data) {
const res = http.get('https://test-api.k6.io/public/crocodiles/');
isRamping(data) ? rampingUp.add(res.timings.duration) : steadyState.add(res.timings.duration);
sleep(3);
function isRamping(data) {
const now = new Date();
return now < new Date(data.rampupDt) || now > new Date(data.rampdownDt);
* Adds time to a date. Modelled after MySQL DATE_ADD function.
* Example: dateAdd(new Date(), 'minute', 30) //returns 30 minutes from now.
* https://stackoverflow.com/a/1214753/18511
* @param date Date to start with
* @param interval One of: year, quarter, month, week, day, hour, minute, second
* @param units Number of units of the given interval to add.
function dateAdd(date, interval, units) {
if(!(date instanceof Date))
return undefined;
var ret = new Date(date); //don't change original date
var checkRollover = function() { if(ret.getDate() != date.getDate()) ret.setDate(0);};
switch(String(interval).toLowerCase()) {
case 'year' : ret.setFullYear(ret.getFullYear() + units); checkRollover(); break;
case 'quarter': ret.setMonth(ret.getMonth() + 3*units); checkRollover(); break;
case 'month' : ret.setMonth(ret.getMonth() + units); checkRollover(); break;
case 'week' : ret.setDate(ret.getDate() + 7*units); break;
case 'day' : ret.setDate(ret.getDate() + units); break;
case 'hour' : ret.setTime(ret.getTime() + units*3600000); break;
case 'minute' : ret.setTime(ret.getTime() + units*60000); break;
case 'second' : ret.setTime(ret.getTime() + units*1000); break;
default : ret = undefined; break;
return ret;
With the above, you just need to make sure you set rampupDt
and rampdownDt
according to your stages
You should end up with output like this:
data_received..................: 18 kB 378 B/s
data_sent......................: 1.9 kB 40 B/s
http_req_blocked...............: avg=16.99ms min=0s med=0s max=254.87ms p(90)=0s p(95)=76.46ms
http_req_connecting............: avg=3.83ms min=0s med=0s max=57.57ms p(90)=0s p(95)=17.27ms
http_req_duration..............: avg=101.63ms min=66.17ms med=86.22ms max=192.96ms p(90)=173.45ms p(95)=191.68ms
{ expected_response:true }...: avg=101.63ms min=66.17ms med=86.22ms max=192.96ms p(90)=173.45ms p(95)=191.68ms
http_req_failed................: 0.00% ✓ 0 ✗ 15
http_req_receiving.............: avg=652.62µs min=0s med=234.2µs max=3.63ms p(90)=1.88ms p(95)=2.84ms
http_req_sending...............: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_tls_handshaking.......: avg=9.51ms min=0s med=0s max=142.75ms p(90)=0s p(95)=42.82ms
http_req_waiting...............: avg=100.98ms min=66.01ms med=85.93ms max=192.83ms p(90)=172.81ms p(95)=190.98ms
http_reqs......................: 15 0.319758/s
iteration_duration.............: avg=2.93s min=998.5µs med=3.09s max=3.34s p(90)=3.2s p(95)=3.24s
iterations.....................: 15 0.319758/s
response_time_ramping..........: avg=110.97054 min=66.1739 med=91.37655 max=192.9672 p(90)=191.31993 p(95)=192.143565
response_time_steady...........: avg=82.96818 min=66.554 med=86.2253 max=102.3571 p(90)=98.08138 p(95)=100.21924
vus............................: 1 min=1 max=1
vus_max........................: 1 min=1 max=1
If you need to break this down further, i.e. having request-level response times instead of a single aggregated metric for all HTTP requests, you would probably need to make use of tags.
