Allright:
I used the following 2 guides/repositories:
Repository 1: https://packages.grafana.com/oss/deb stable main
Repository 2: https://dl.grafana.com/enterprise/release/grafana-enterprise-rpi_9.3.2_armhf.deb
Output of “uname -a”: Linux raspberrypi 5.15.84+ #1613 Thu Jan 5 11:58:09 GMT 2023 armv6l GNU/Linux
Jan 18 16:55:27 raspberrypi systemd[1]: Stopped Grafana instance.
Jan 18 16:55:27 raspberrypi systemd[1]: grafana-server.service: Consumed 10.332s CPU time.
Jan 18 16:55:27 raspberrypi systemd[1]: Started Grafana instance.
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.637383871+01:00 level=info msg=“Starting Grafana” version=9.3.2 commit=21c1d14e91 branch=HEAD compiled=2022-12-14T11:40:18+01:00
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.674781411+01:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.680724338+01:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.685927274+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.714391923+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.720958842+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.753992435+01:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.75930937+01:00 level=info msg=“Path Home” path=/usr/share/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.764496306+01:00 level=info msg=“Path Data” path=/var/lib/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.765191297+01:00 level=info msg=“Path Logs” path=/var/log/grafana
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.766059287+01:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.766784278+01:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=settings t=2023-01-18T16:55:37.767466269+01:00 level=info msg=“App mode production”
Jan 18 16:55:37 raspberrypi grafana-server[1116]: logger=sqlstore t=2023-01-18T16:55:37.78525805+01:00 level=info msg=“Connecting to DB” dbtype=sqlite3
Jan 18 16:55:37 raspberrypi grafana-server[1116]: unexpected fault address 0x3da2558
Jan 18 16:55:37 raspberrypi grafana-server[1116]: fatal error: fault
Jan 18 16:55:37 raspberrypi grafana-server[1116]: [signal SIGSEGV: segmentation violation code=0x2 addr=0x3da2558 pc=0x28e88f8]
Jan 18 16:55:37 raspberrypi grafana-server[1116]: goroutine 1 [running]:
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime.throw({0x32a8b7d, 0x5})
Jan 18 16:55:37 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/panic.go:1047 +0x4c fp=0x789f3a4 sp=0x789f390 pc=0x5c8d4
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime.sigpanic()
Jan 18 16:55:37 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/signal_unix.go:842 +0x1d0 fp=0x789f3bc sp=0x789f3a4 pc=0x766c0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: runtime: g 1: unexpected return pc for _cgo_topofstack called from 0xa6b22424
Jan 18 16:55:37 raspberrypi grafana-server[1116]: stack: frame={sp:0x789f3c0, fp:0x789f3cc} stack=[0x7880000,0x78a0000)
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f340: 0x0005ea14 <runtime.gwrite+0x00000034> 0x0005eac4 <runtime.gwrite+0x000000e4> 0x00000002 0x03ad5ee4
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f350: 0x00000001 0x00000001 0x0005f2e0 <runtime.printstring+0x00000060> 0x00000002
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f360: 0x03ad5ee4 0x00000001 0x00000001 0x000931e4 <runtime.systemstack+0x0000004c>
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f370: 0x0005cbb8 <runtime.fatalthrow+0x00000064> 0x0005c8d4 <runtime.throw+0x0000004c> 0x0789f380 0x06c020f0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f380: 0x0005cbd0 <runtime.fatalthrow.func1+0x00000000> 0x06c020f0 0x0005c8d4 <runtime.throw+0x0000004c> 0x0789f390
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f390: 0x000766c0 <runtime.sigpanic+0x000001d0> 0x00000002 0x0005c8e0 <runtime.throw.func1+0x00000000> 0x032a8b7d
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3a0: 0x00000005 0x00094dfc <_cgo_topofstack+0x00000010> 0x032a8b7d 0x00000005
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3b0: 0x00094dfc <_cgo_topofstack+0x00000010> 0x03da2558 0x06c020f0 0x00094dfc <_cgo_topofstack+0x00000010>
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3c0: <0xa6b22424 0x02095260 <github### . removed due to link restriction# com/grafana/grafana/pkg/extensions/caching.AddMigration+0x00000d78> 0x071ab5c0 >0x0000002e
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3d0: 0x03afdac4 0x06ca4258 0x00000000 0x00000000
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3e0: 0x00000000 0x071ab598 0x00000001 0x00000001
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f3f0: 0x06ca4228 0x071625c0 0x00000002 0x00000000
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f400: 0x00000006 0x00d24248 <github### . ### com/grafana/grafana/pkg/services/sqlstore/migrator.(*Migrator).AddMigration+0x00000148> 0x072fb200 0x138b1414
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f410: 0x06ca4258 0x06ca4240 0x07162600 0x071625e0
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f420: 0x2b4f4832 0x06daeab0 0x06daea80 0x06ca4268
Jan 18 16:55:37 raspberrypi grafana-server[1116]: 0x0789f430: 0x032a488f 0x06ca4210 0x06ca4270 0x071ab598
Jan 18 16:55:38 raspberrypi grafana-server[1116]: 0x0789f440: 0x06ca4210 0x06ed4c20 0x03344b91
Jan 18 16:55:38 raspberrypi grafana-server[1116]: _cgo_topofstack()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:820 +0x10 fp=0x789f3cc sp=0x789f3c0 pc=0x94dfc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 2 [force gc (idle)]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x573a090, 0x11, 0x14, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5afd8 sp=0x6c5afc4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.goparkunlock(…)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:369
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.forcegchelper()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:302 +0xc4 fp=0x6c5afec sp=0x6c5afd8 pc=0x5fbf0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.goexit()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5afec sp=0x6c5afec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.init.5
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:290 +0x1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 3 [runnable]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.Gosched(…)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:318
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.bgsweep(0x6c78000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcsweep.go:283 +0x13c fp=0x6c5b7e4 sp=0x6c5b7d0 pc=0x471fc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcenable.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:178 +0x28 fp=0x6c5b7ec sp=0x6c5b7e4 pc=0x37830
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5b7ec sp=0x6c5b7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.gcenable
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:178 +0x74
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 4 [GC scavenge wait]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x5740330, 0xd, 0x14, 0x2)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5bfb4 sp=0x6c5bfa0 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.(*scavengerState).park(0x5740330)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcscavenge.go:389 +0x64 fp=0x6c5bfc8 sp=0x6c5bfb4 pc=0x44be4
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.bgscavenge(0x6c78000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgcscavenge.go:622 +0x64 fp=0x6c5bfe4 sp=0x6c5bfc8 pc=0x45338
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcenable.func2()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:179 +0x28 fp=0x6c5bfec sp=0x6c5bfe4 pc=0x377dc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5bfec sp=0x6c5bfec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:179 +0xbc
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 5 [finalizer wait]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f50, 0x581d954, 0x10, 0x14, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5a78c sp=0x6c5a778 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.runfinq()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mfinal.go:180 +0x108 fp=0x6c5a7ec sp=0x6c5a78c pc=0x36870
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5a7ec sp=0x6c5a7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.createfing
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mfinal.go:157 +0x54
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 18 [GC worker (idle)]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5e10, 0x6c4a978, 0x18, 0x14, 0x0)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5c790 sp=0x6c5c77c pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gcBgMarkWorker()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:1235 +0x100 fp=0x6c5c7ec sp=0x6c5c790 pc=0x3a448
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5c7ec sp=0x6c5c7ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by runtime.gcBgMarkStartWorkers
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/mgc.go:1159 +0x20
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 28 [chan receive]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5ddc, 0x6d00670, 0xe, 0x17, 0x2)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c5cf5c sp=0x6c5cf48 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.chanrecv(0x6d00640, 0x6c5cfd0, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/chan.go:583 +0x530 fp=0x6c5cfa8 sp=0x6c5cf5c pc=0x20828
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.chanrecv2(0x6d00640, 0x6c5cfd0)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/chan.go:447 +0x20 fp=0x6c5cfbc sp=0x6c5cfa8 pc=0x202ec
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/golang/glog.(*loggingT).flushDaemon(0x57401e8)
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:882 +0x70 fp=0x6c5cfe4 sp=0x6c5cfbc pc=0x102fdd0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/golang/glog.init.0.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:410 +0x28 fp=0x6c5cfec sp=0x6c5cfe4 pc=0x102e114
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c5cfec sp=0x6c5cfec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by github###.###com/golang/glog.init.0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/golang/glog@v1.0.0/glog.go:410 +0x210
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 98 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.gopark(0x34e5f7c, 0x0, 0x9, 0x18, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c576ec sp=0x6c576d8 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c577cc, 0x6c577b8, 0x0, 0x0, 0x3, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c57794 sp=0x6c576ec pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: go###.###opencensus###.io/stats/view.(*worker).start(0x746ef60)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:276 +0xa0 fp=0x6c577e4 sp=0x6c57794 pc=0x141e4a0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: go###.###opencensus###.io/stats/view.init.0.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x28 fp=0x6c577ec sp=0x6c577e4 pc=0x141d7f0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c577ec sp=0x6c577ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by go.###opencensus#.io/stats/view.init.0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/go.opencensus.io@v0.23.0/stats/view/worker.go:34 +0x98
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 142 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c57ef8 sp=0x6c57ee4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c57fcc, 0x6c57fc4, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c57fa0 sp=0x6c57ef8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).connectionOpener(0x78b5ef0, {0x3af88f0, 0x6d8d3e0})
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1224 +0x9c fp=0x6c57fdc sp=0x6c57fa0 pc=0xc29888
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.OpenDB.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:792 +0x38 fp=0x6c57fec sp=0x6c57fdc pc=0xc27b04
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c57fec sp=0x6c57fec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by database/sql.OpenDB
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Failed with result ‘exit-code’.
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:792 +0x188
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 141 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c586f8 sp=0x6c586e4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c587d0, 0x6c587c4, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c587a0 sp=0x6c586f8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github.##com##/patrickmn/go-cache.(*janitor).Run(0x6c371f0, 0x6d8d320)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1079 +0x98 fp=0x6c587e0 sp=0x6c587a0 pc=0xd494f0
Jan 18 16:55:38 raspberrypi grafana-server[1116]: github###.###com/patrickmn/go-cache.runJanitor.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x30 fp=0x6c587ec sp=0x6c587e0 pc=0xd496c8
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c587ec sp=0x6c587ec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by github###.###com/patrickmn/go-cache.runJanitor
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/opt/drone/gomodcache/github.com/patrickmn/go-cache@v2.1.0+incompatible/cache.go:1099 +0x104
Jan 18 16:55:38 raspberrypi grafana-server[1116]: goroutine 143 [select]:
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/proc.go:363 +0x100 fp=0x6c58ed8 sp=0x6c58ec4 pc=0x5fd8c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: runtime.selectgo(0x6c58fcc, 0x6c58fb8, 0x0, 0x0, 0x2, 0x1)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/select.go:328 +0xb64 fp=0x6c58f80 sp=0x6c58ed8 pc=0x72a1c
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).connectionCleaner(0x78b5ef0, 0xd18c2e28000)
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1067 +0xe8 fp=0x6c58fdc sp=0x6c58f80 pc=0xc28ca8
Jan 18 16:55:38 raspberrypi grafana-server[1116]: database/sql.(*DB).startCleanerLocked.func1()
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1054 +0x38 fp=0x6c58fec sp=0x6c58fdc pc=0xc28b94
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/runtime/asm_arm.s:831 +0x4 fp=0x6c58fec sp=0x6c58fec pc=0x94e18
Jan 18 16:55:38 raspberrypi grafana-server[1116]: created by database/sql.(*DB).startCleanerLocked
Jan 18 16:55:38 raspberrypi grafana-server[1116]: #011/usr/local/go/src/database/sql/sql.go:1054 +0x204
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Consumed 10.457s CPU time.
Jan 18 16:55:38 raspberrypi systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 12.
Jan 18 16:55:38 raspberrypi systemd[1]: Stopped Grafana instance.
There seems to be a Segementation violation - I have no idea to be honest what is the probleme there ;( Maybe Someone can have a look at it and give me some hints.
Thanks a lot so far.
