REG:SQL metrices
Hi…
I want to display a panel with Buffer cache hit ratio.
I know the query for that
SELECT (a.cntr_value * 1.0 / b.cntr_value) * 100.0 as BufferCacheHitRatio
FROM sys.dm_os_performance_counters a
JOIN (SELECT cntr_value,OBJECT_NAME
WHERE counter_name = 'Buffer cache hit ratio base’
AND OBJECT_NAME = ‘SQLServer:Buffer Manager’) b ON a.OBJECT_NAME = b.OBJECT_NAME
WHERE a.counter_name = 'Buffer cache hit ratio’
AND a.OBJECT_NAME = ‘SQLServer:Buffer Manager’
But how can i pull this off in grafana.
When i try to query it shows a lot of measurements with different names from sql tables.
I am new to grafana ,so excuse me if it sounds stupid.?
Additional info…I am using a telegrf agent and using sql server plugin.
Are you using the MySQL data source? What panel are you using? What is the error ?
I am using SQL Server 2008 and telegraf agent to capture the SQL performance metrics.
i added new panel and if i try to query if is showing different table(measurements) names.
For example:
If i want to query Buffer cache hit ration in SQL server,i do that as below:
If i want to do the same in grafana how do i query Influxdb ,coz i dont know that what is the measure name for that.
I am using the telegraf sql server plug which garafana provide.
InfluxDB does not support joins, please look at InfluxDB docs for details on the InfluxDB query language
okay i have checked Influxdb querying ,but it saws how to query to the measurements collected by telegraf.
I want to know how i can create a measurement which corresponds to the above query.
Considering i am new to GO language how can i achieve the above query in my question.
InfluxDB is not a SQL database so it’s impossible.
What measurements do you have in InfluxDB?
I have;
Performance counters : 1000+ metrics from sys.dm_os_performance_counters
Performance metrics : special performance and ratio metrics
Wait stats : wait tasks categorized from sys.dm_os_wait_stats
Memory clerk : memory breakdown from sys.dm_os_memory_clerks
Database size : databases size trend from sys.dm_io_virtual_file_stats
Database IO : databases I/O from sys.dm_io_virtual_file_stats
Database latency : databases latency from sys.dm_io_virtual_file_stats
Database properties : databases properties, state and recovery model, from sys.databases
OS Volume : available, used and total space from sys.dm_os_volume_stats
CPU : cpu usage from sys.dm_os_ring_buffers
so we can only use whatever the telegraf collects.?
There is no way to manipulate or visualize a better insight?
coz what i was thinking was to add a table in the grafana dashboard to visualize sp_whoisactive query result with all the columns of the sp_whoisactive as Tags.
You can only query InfluxDB fields and measurements that telegraf collects, and the InfluxDB query language is very limited
How do we know then this measurement name gets this particular data ?
