Rename a datasource which was provisioned using a file
Hi Grafana Team!
I have a datasource which is provisioned using a file.
The file looks like below,
apiVersion: 1
datasources:
  - name: Druid
    version: 1
    type: grafadruid-druid-datasource
    access: proxy
    orgId: 1
    uid: _Pvp4QWYS
    isDefault: true
    jsonData:
      connection.basicAuth : true
      connection.url: mu_url
      connection.basicAuthUser: my_user
    secureJsonData:
      connection.basicAuthPassword: my_password
    editable: false
    enabled: true
Everything is working fine.
Now, I want to rename this datasource to Druid - Events, so I made the following changes,
datasources:
  - name: Druid - Events
    version: 2
However, now when I restart Grafana with the updated file, I get this error,
logger=provisioning.datasources t=2023-01-30T12:42:56.376372465Z level=info msg="inserting datasource from configuration " name="Druid - Events" uid=_Pvp4QWYS
logger=provisioning t=2023-01-30T12:42:56.398055752Z level=error msg="Failed to provision data sources" error="Datasource provisioning error: data source with the same uid already exists"
I looks like Grafana is trying to insert a new Datasource rather than updating the existing one.
Can someone help me out here please? How do I make Grafana update the same datasource rather than make it create another one?
    I am on Grafana v9.3.6
    Trying to update the name of a datasource which was provisioned using a file.
    By updating the provisioning file
  • What happened?
    Grafana fails to start with the following error,
    Grafana should rename the datasource
    See above
    See above
    Followed instructions from here: Provision Grafana | Grafana documentation
