v8.0.3 Windows -
I have 2 variables.
Variable1: FOO,BAR,BAS,
Variable2: A MSSQL query that returns a key-value pair such as FOO_ETC:12, BAR_ETC:12
I have a panel that repeats for each value in Variable1, which is used in most queries.
I would like to add a query using the respective value of Variable2: so for example in the FOO panel instance, use the value 12.
I know that if the panels were repeating on Variable2 instead of 1, I could get that value easily with {Variable2:value}. However, I have to use Variable1 (because in some cases Variable2 doesn’t have an entry but I still want to show the other queries).
I’d think it would be possible to somehow, for each panel instance:
- Create the corresponding Variable2 string, based on the value of Variable1 - this is possible with “${Variable1}_ETC” → “FOO_ETC”
- Use the string above to access the corresponding value of Variable2. Really just like using a key in a dictionary. In Python terms for example, as Variable2[“FOO_ETC”]. But I’m not aware of this being possible in key-value variables in Grafana.
I’ve read a lot of questions and documentation but couldn’t come up with anything to get started. -
What happened?
N/A -
N/A -
See above -
Didn’t get to this point -
Did you follow any online instructions? If so, what is the URL?
N/A
