Resample returns "No data"
Grafana v7.5.7 (91de51771c)
My problem: I have several metrics in Azure SQL that are misaligned in time.
What I want to do: I want to align the metrics in time.
What I did:
As expected, Grafana displays the misaligned metrics if I delete the Expression Query “b” and I just run the query “a”.
Once I add the Expression Resample “b” Grafana displays the message “no data”.
I followed the documentation Query and transform data | Grafana documentation
The problem seems similar to what is described in this old post from 2019 https://localhost:3000/t/expression-in-query/43325
The post does not offer the solution to this issue.
Hi @rmx
Expressions like resample are still a beta feature.
Do you think you could accomplish something using transformations instead? Or performing operations on the db side?
