I am currently developing a panel where we want to reuse the same colour palette as grafana, but I cannot seem to find exactly how to get it when i was checking out the grafana code
=> it looks like I need the palette from the theme and the label of the colour palette from the config and i tried multiple functions i found in the grafana code base, but I could not manage to get the correct colour palette.
Is there some documentation somewhere on the subject?
those only seem to talk about the color palette from the theme, but not about how to get the color-sheme for the config (e.g. timeseries-panel => standard options => color":{“mode”:“continuous-GrYlRd”}})
i need to map that string (“continuous-GrYlRd”) to the same color palette that grafana uses for that param, but i haven’t been able to figure out how to do this
I’m not sure you can get a full color palette for the field options, but you can get the color for a specific value in your query results by using the display processor. The display processor uses the color from the standard options.
Each data frame field has a method called display that accepts a value and returns an object with information on that value should be presented.
