Reverse proxy - delayed connect error: 111
    Grafana 9.3.1 installed on Ubuntu 22.04 via apt-get
    Simple reverse proxy without subpath
    Following the documentation Run Grafana behind a reverse proxy | Grafana Labs
    With an nginx proxy
  • What happened?
    Grafana works well, but arround one of ten request (including requesting html, js, css, imgs, /api …) to the proxy fails with the following error :
upstream connect error or disconnect/reset before headers. reset reason: connection failure, transport failure reason: delayed connect error: 111
The http request that fails change at every reload, sometimes it can’t request the js files, sometimes the css and sometimes everything loads well but some /api request fails
    All requests to the grafana server should succeed
# grafana.ini (params that are not listed here are still commented
app_mode = production
[server]
http_port = 3000
domain = grafana.**********.com
# tried to enable/disable subpath
# nginx grafana.conf
map $http_upgrade $connection_upgrade {
  default upgrade;
  '' close;
upstream grafana {
  server localhost:3000;
server {
  listen 80;
  root /usr/share/nginx/html;
  index index.html index.htm;
  server_name grafana.****************.com;
  location / {
    proxy_set_header Host grafana.***************.com;
    proxy_pass http://grafana;
  # Proxy Grafana Live WebSocket connections.
  location /api/live/ {
    proxy_http_version 1.1;
    proxy_set_header Connection $connection_upgrade;
    proxy_set_header Host $http_host;
    The following error is shown in “popovers” inside Grafana UI, but is not visible in logs (grafana nor nginx)
Thanks for your help.
For those who has a similar problem :
The issue was caused by my load balancer.
