Reverse Proxy + serve_from_sub_path
I updated grafana to version v9.3.2 (21c1d14e91)
Grafana is behind reverse proxy, alongside with other services. Worked fine with previous versions, now I found a little bug (?)
log in link is not correct as it shout be mydomain/grafana/login - and it is mydomain/login
while after logging in - all works perfectly, and links are correct
