Hi Team,
I already using the k6 protocol level test for the last couple of months, now I’m planning for a Hybrid approach to run Browser automation along with the HTTP protocol test.
Currently I’m running a Protocol level test on Jenkins Slave or AWS CodeBuild based on the situation. if I run the test on headless mode, Is it required to install Chrome binary on those slave hosts, Or need to set any options on AWS CodeBuild?
Currently running the test with
docker run -i grafana/k6 run --out influxdb=… - <script.js
Is it required to pass additional parameters like below?
docker run K6_BROWSER_ENABLED=true -i grafana/k6 run --out influxdb=… - <script.js
