Hey everyone,
I’m using K6 operator and I’m trying to run a distributed load test on EKS with AWS auto-scaling node groups.
I’ve setup cluster autoscaler and it does autoscale my nodes if I set something like this in my K6 CRD:
resources:
limits:
cpu: 600m
memory: 1Gi
requests:
cpu: 100m
memory: 1Gi
However, my goal is to have every pod during my load test be run on a separate node (which means I’d like my node group to autoscale to the size of parallelism in the CRD).
I tried doing this with anti-affinity groups and couldn’t get it to work.
I then tried using separate: true as outlined in the operator documentation and I’m getting some strange behaviour.
For example, if I have parallelism set to 10, and I have a node group on EKS with a minimum of 2 and a maximum of 10, when I set separate:true it will create one additional node and give me 3 nodes. And all the other pods will remain in a “pending” state.
If I try to cancel and run it again, the same will happen. This time I’ll get one extra node which will give me a total of 4 nodes and all the other pods will remain in a pending state.
Any idea why this is happening. Would appreciate any help.
Here’s my CRD file:
apiVersion: k6.io/v1alpha1
kind: K6
metadata:
labels:
app: load
spec:
parallelism: 10
script:
configMap:
file: "test.js"
separate: true
arguments: --out statsd
runner:
metadata:
labels:
app: load
# resources:
# limits:
# cpu: 600m
# memory: 1Gi
# requests:
# cpu: 100m
# memory: 1Gi
env:
- name: K6_STATSD_ADDR
value: "statsd-service:8125"
# affinity:
# podAntiAffinity:
# requiredDuringSchedulingIgnoredDuringExecution:
# - labelSelector:
# matchExpressions:
# - key: app
# operator: In
# values:
# - load
# topologyKey: kubernetes.io/hostname
