Hi there,
I have already k6 cloud (free) account and CircleCI configured to run k6 there along with the existing workflows, orbs etc (not grafana/k6 orb).
I think it is possible to use k6 cloud for free just to transfer the output results there from k6 testing in CircleCI?
So, I would like to configure my CircleCI pipeline (.circleci/config.yml) and I already set K6_CLOUD_TOKEN
variable in CircleCI.
What else I need to do in order to make this happen? I tried to just put cloud: true
in my workflow in config.yml
, but then I have failed CI pipeline saying that cloud
is not permitted to use (extraneous key [cloud] is not permitted).
As mentioned, I have jobs, workflows… but for a single performance_tests
workflow I would like to transfer every test run to k6 cloud, if possible.
Example job:
performance_tests:
working_directory: /home/circleci/project
machine:
image: ubuntu-2204:2022.10.2
docker_layer_caching: false
parameters:
mysql_command:
type: string
default: ''
mysql_image:
type: string
default: ''
wordpress_image_version:
type: string
default: ''
url:
type: string
default: 'http://localhost:9500'
pw:
type: string
default: 'password'
scenario:
type: string
default: 'pullrequests'
steps:....
