Running maintenance failed of alertmanager
I have downloaded the latest Grafana source code and set up my development environment. After running the frontend and backend, it starts showing up in the error logging. I haven’t made any changes to the source code yet.
ERROR Running maintenance failed logger=alertmanager err=“context canceled”
Can anyone explain what is causing this error?
hi @adeel86
could you share the part concerning unified alerting in your config file ?
it might also help to know the following details:
  • Grafana version:
  • OS Grafana is installed on:
  • User OS & browser version
  • Did you follow any online instructions for installing Grafana? If so, what is the URL?
#################################### Unified Alerting ####################
[unified_alerting]
#Enable the Unified Alerting sub-system and interface. When enabled we'll migrate all of your alert rules and notification channels to the new system. New alert rules will be created and your notification channels will be converted into an Alertmanager configuration. Previous data is preserved to enable backwards compatibility but new data is removed.```
;enabled = true
# Comma-separated list of organization IDs for which to disable unified alerting. Only supported if unified alerting is enabled.
;disabled_orgs =
# Specify the frequency of polling for admin config changes.
# The interval string is a possibly signed sequence of decimal numbers, followed by a unit suffix (ms, s, m, h, d), e.g. 30s or 1m.
;admin_config_poll_interval = 60s
# Specify the frequency of polling for Alertmanager config changes.
;alertmanager_config_poll_interval = 60s
# Listen address/hostname and port to receive unified alerting messages for other Grafana instances. The port is used for both TCP and UDP. It is assumed other Grafana instances are also running on the same port. The default value is `0.0.0.0:9094`.
;ha_listen_address = "0.0.0.0:9094"
;ha_advertise_address = ""
# Comma-separated list of initial instances (in a format of host:port) that will form the HA cluster. Configuring this setting will enable High Availability mode for alerting.
;ha_peers = ""
# Time to wait for an instance to send a notification via the Alertmanager. In HA, each Grafana instance will
# be assigned a position (e.g. 0, 1). We then multiply this position with the timeout to indicate how long should
# each instance wait before sending the notification to take into account replication lag.
;ha_peer_timeout = "15s"
# The interval between sending gossip messages. By lowering this value (more frequent) gossip messages are propagated
# across cluster more quickly at the expense of increased bandwidth usage.
;ha_gossip_interval = "200ms"
# The interval between gossip full state syncs. Setting this interval lower (more frequent) will increase convergence speeds
# across larger clusters at the expense of increased bandwidth usage.
;ha_push_pull_interval = "60s"
# Enable or disable alerting rule execution. The alerting UI remains visible. This option has a legacy version in the `[alerting]` section that takes precedence.
execute_alerts = false
# Alert evaluation timeout when fetching data from the datasource. This option has a legacy version in the `[alerting]` section that takes precedence.
# The timeout string is a possibly signed sequence of decimal numbers, followed by a unit suffix (ms, s, m, h, d), e.g. 30s or 1m.
;evaluation_timeout = 30s
# Number of times we'll attempt to evaluate an alert rule before giving up on that evaluation. This option has a legacy version in the `[alerting]` section that takes precedence.
;max_attempts = 3
# Minimum interval to enforce between rule evaluations. Rules will be adjusted if they are less than this value  or if they are not multiple of the scheduler interval (10s). Higher values can help with resource management as we'll schedule fewer evaluations over time. This option has a legacy version in the `[alerting]` section that takes precedence.
;min_interval = 10s
[unified_alerting.reserved_labels]
# Comma-separated list of reserved labels added by the Grafana Alerting engine that should be disabled.
# For example: `disabled_labels=grafana_folder`
;disabled_labels =
Hi! This is a bug in 9.4.1 and 9.4.2, please upgrade to 9.4.3.
The upgrade to 9.4.3 fixed this issue.
Thanks.
