Samsung Signage (MagicInfo) TV can't display Dashboard
    Grafana 8.3.3 in Docker
    Ubuntu OS
    See my Dashboard on the Samsung Smart Signage QM32R TV.
    MagicInfo Server or the TV build in WebBrowser (TizenBrowser)
  • What happened?
    Next error:
    Load Grafana Dashboard.
Can I get Some help? Someone has a solution for this problem?
Thank you!
What browser does this tv use?
Samsung Smart Signage Webbrowser (TizenBrowser)
Please check this page out
Another option might be installing Chrome on the tv?
Hello!
I tested out with grafana 6.0.0. And It’s working on the TV. But above that version i got the error.
So, looks like the Grafana does not support samsung browser above ~6.0.0.
