Hi everyone, I am new to the K6 tool.
Is there a way to save the response obtained in first iteration to a variable and then use it the subsequent iteration in the same VU?
What I would like to do is get the header data in response like ‘Etag’, ‘Last-Modified’ and then set it in the request’s header for the following iteration in the same VU. Pretending a user come back to the URL he visited before.
Is that even possible?
Thanks in advance
Not sure I understand fully what you mean, but you can do something like this:
let persistentData = null;
export default function() {
if persistentData === null {
let resp = http.get("https://whatever");
persistentData = resp.headers['Etag'];
Any global variables like persistentData
can be initialized in the first iteration of the VU and will be preserved and accessible for subsequent iterations of the same VU. Also take a look at the k6/execution
module, it exposes various properties of the current k6 execution state about the test, vu and iteration that you can use in if
statements to manage such things.
Thanks a lot Ned! That’s what I need.
I used the headers saved in the “persistentData” and modified the request headers. The server returned HTTP 304 (Not modified), so no more re-download of the resources.
const params = {
headers: { 'If-None-Match': `${etag}`, 'If-Modified-Since': `${lastModified}` },
res = http.get(url, params);
