Here’s a simple example (referred to as test.js
below):
import http from 'k6/http';
export const options = {
scenarios: {
example_scenario: {
executor: 'shared-iterations',
env: { EXAMPLEVAR: 'testing' }
export default function () {
console.log('__ENV.EXAMPLEVAR: ' + __ENV.EXAMPLEVAR)
http.get('https://test.k6.io');
When I run k6 run test.js
, I see __ENV.EXAMPLEVAR: testing
as expected. However, when I run k6 run --vus 10 --duration 30s test.js
or k6 run --vus 10 --iterations 100 test.js
, I see __ENV.EXAMPLEVAR: undefined
Is this a bug, or is there a way to change the script to fix this?
As a workaround, setting iterations
and vus
in options
like this instead of passing them to k6 run
works:
scenarios: {
example_scenario: {
env: { EXAMPLEVAR: 'testing' },
iterations: 100,
vus: 10
Hi @bslaught , welcome to the community forum.
Effectively using any of the --iteration
/-i
, --duration
/-d
, --vus
/-u
options tells k6 “don’t look at options.scenarios
, build me a new one with one executor that has these properties”. While in your case you can argue that this should work - it can’t in the general one:
- combinations of the three option can configure different executor types - different than
shared-iterations
- you have one executor, but you can have multiple ones.
Hope this explains why this happens
I see. It might help to print a message stating that scenarios are being ignored (I see scenarios: (100.00%) 1 scenario, 10 max VUs, 1m0s max duration (incl. graceful stop)
when providing these options), or note in Scenarios that scenarios are skipped when these options are passed.
That doesn’t seem like a bad idea I guess - I’ve opened an issue. You can add more info if you want.
Although there is already some evidence in the output - just on the line below the one you quoted you will see the name of the scenario(s) and it changes from example_scenario
to default
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* example_scenario: 1 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
* default: 2 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
Oh, I had missed that. Thanks for looking and opening the issue!
