Hello, I am using scripted dashboard to create the same dashboard for different databases depending on an input. And it works great.
However, there is one issue I don’t seem to be able to fix. The values I assign to the gridpos variables seems to be totally ignored when generating the page, everything else works
This is the file I am using
/* global _ */
'use strict';
// accessible variables in this scope
var window, document, ARGS, $, jQuery, moment, kbn;
// Setup some variables
var dashboard;
// All url parameters are available via the ARGS object
var ARGS;
dashboard = {
rows : [],
dashboard.title = ARGS.ip + ' Dashboard';
dashboard.time = {
to: "now"
dashboard.editable = true; //Should only be true while working on scripted dashboard.
dashboard.refresh = "10s"; // updates all panels every 10 seconds
var mac = 'DefaultMac';
if(!_.isUndefined(ARGS.mac)) {
mac = ARGS.mac;
dashboard.rows.push({
title: 'Chart',
panels: [
steppedLine: true,
type: 'graph',
datasource: 'TestProtocolDB',
title: "Load Average",
span: "12",
"nullPointMode": "connected",
fill: 1,
linewidth: 2,
gridPos: {
"h": 8,
"w": 12,
"x": 0,
"y": 0
legend: {
"avg": true,
"current": true,
"max": true,
"min": true,
"show": true,
"total": false,
"values": true
targets: [
"measurement": ("AvgLo-" + mac),
"refId": "A",
"orderByTime": "ASC",
"policy": "default",
"resultFormat": "time_series",
"alias": "Load Average",
tooltip: {
shared: true
steppedLine: true,
type: 'graph',
title: "Memory",
span: "12",
fill: 1,
linewidth: 2,
gridPos: {
"h": 8,
"w": 12,
"x": 12,
"y": 0
legend: {
"alignAsTable": true,
"avg": true,
"current": false,
"max": true,
"min": true,
"show": true,
"total": false,
"rightSide": true,
"values": true
targets: [
"measurement": ("MemTo-" + mac),
"refId": "Memory Total",
"alias": "Memory Total",
"measurement": ("MemFr-" + mac),
"refId": "Memory Free",
"alias": "Memory Free",
"measurement": ("Cache-" + mac),
"refId": "Cache",
"alias": "Cache",
tooltip: {
shared: true
return dashboard;
However when looking at the JSON model of the dashboard, the first gridpos is always:
"h": 7,
"w": 24,
"x": 0,
"y": 0
And the second is always:
"h": 7,
"w": 24,
"x": 0,
"y": 7
Despite me setting it to something else. Scripted dashboards works exactly fitting the task at hand and this isn’t a huge issue, its just kinda annoying aesthetically. So if there is a fix i would like to know it.
