Secondary axis option vanished?
Grafana 9.3.1 running on raspberry pi os (fully updated)
Showing in Firefox 107.0.1 on Windows 10 22h2
I try to move one series to a secondary Y axis
Clicking the color legend to open the popup dialog where I had an option to move that particular series to secondary axis
  • What happened?
No secondary y-axis in the menu anymore
A popup giving me the ability to move a series to secondary axis
no
No
I am also facing the same issue. In Grafana 9.3, Dual-Y Axis option isn’t visible
Use Overrides:
Why is it hidden so far away ? It was in a very good location to move a graph quickly to the secondary axis, especailly when suddenly there’s a large difference between graphs.
With the overrides, you can only make it as a permanent setting which requires editing from the user which is not an option in our environment.
How can we get back the secondary axis option in the place where it used to be as a temporary change ?
