Send single message per alert
    v8.4.1 hosted on Kubernetes
    Send a single alert for each alert (state change).
    Added a template, called SingleAlertContent :
{{ define "SingleAlertContent" }}
  Value: {{ or .ValueString "[no value]" }}
  Labels:
  {{ range .Labels.SortedPairs }}
    {{ .Name }}: {{ .Value }}
  {{ end }}
  {{ if gt (len .Annotations) 0 }}
  Annotations:
  {{ range .Annotations.SortedPairs }}
  {{ end }}
  {{ end }}
  {{ if gt (len .DashboardURL ) 0 }}
    Go to dashboard: {{ .DashboardURL }}
  {{ end }}
  {{ if gt (len .PanelURL) 0 }}
    Panel: {{ .PanelURL }}
  {{ end }}
{{ end }}
Added another template, called SingleAlertTitle:
{{ define "SingleAlertTitle" }}
  [{{ .Status | toUpper }}] {{ .Labels.alertname }} {{ if gt (len .Alerts.Firing) 0 }}firing:{{ .Alerts.Firing | len }}{{ end }}
{{ end }}
Used the templates in my default, Slack, contact point:
  • Title: {{ template “SingleAlertTitle” . }}
  • Text Body: {{ template “SingleAlertContent” . }}
Fired a test notification from within the contact point.
  • What happened?
    A Slack message was sent with only the state [FIRING] (from the title) in it.
    Grafana APP 1052
    This is what the same test notification looks like, without the templates:
    Get a Slack message that contains the details for the single alert.
    The actual goal is to get a single message for each alert, like we did before in Grafana v7.
    The templates in the snippets above, or just an attempt to achieve this.
Bump
(not sure if this is allowed, but I’m really stuck here… :pray:)
Try to use {{ .CommonLabels.alertname }} instead of {{ .Labels.alertname }}.
