Series Override - Color. Does not work
If I have a Graph with lines, then I want to override the color to be specific to a color scheme for the metric items.
When I set this manually, it is not retained when selecting different metric where some metrics do not have a value.
I went to series override to always set specific metrics to a color, but when I select the “color” override and the “change” option I get a bunch of errors in the browser:
Firstly, this is what appears:
Then in the Chrome Console:
what version of grafana are you using?
v4.6.0
commit: c47f670a5
The. Upgrade this is fixed in latest stable
Thanks, that has fixed it.
