Set axis scaling with variables
    tested on v8.2.5 and 9.3.6, CentOS
    Give non editors the chance to set min/max of y-axis via defined variables
    Setting up variables (Y_MIN/Y_MAX) and use them in panel/axis options (as “$Y_MIN”)
  • What happened?
    For (soft)min/max nothing happened. Label schows the text, but not the value of the variable.
    For the panel title (=Y_MIN) it is working!
    Min/max settings of axis should take value of variable.
Hi @jepek,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
This seems to be a known feature request:
I would recommend giving more upvotes to it so that it gets more priority and visibility to get on the roadmap.
