Setting column width in table panel
Is there a possibility to adjust the column width in a table panel? I have 4 columns which should all have the same width (25%). Unfortunately they all have a different size.
No there is no option for this currently.
any updates on that?
Any update on that? It’s 2020, setting width in pixels only for various display types w/ different DPI is silly nowadays %(
Really, there is no option? Feels hard to believe that…
Seems it will be supported in v7.6 (see Table field options | Grafana Labs)
