I have setup a pair of custom timestamp variables which are being read from an InfluxDB datasource.
I can view these in a SingelStat panel, but i’d like to use them to set the time range in a particular graph panel (as i’m only interested in the data in this time period).
Is this possible?
Thanks, Mike
Hi @mikejsmith ! did you manage to do that? I’m in the same need.
tgruse
August 25, 2020, 5:37am
3
I have the same problem! I’m trying all week without solution.
did you guys found any solution?
Hi @vsharma2be18 ,
Welcome to the community support forums !!
This post is almost 2 years old so not sure if all of the above users are still active or not.
However, you can still ask your question here, Please review the submission template and include more details:
What is your datasource?
What visualization panel you are using e.g. time-series, bar chart, histogram etc?
What happened?
Did you follow any online instructions? If so, what is the URL?
