Grafana version: v9.3.4 Windows
Change a simple “CPU usage” gauge so it is able to show multiple nodes (in multiple gauges):
I tried to use the “repeat for” option to show one gauge per node. The Gauge has a query variable named $node and defined as: label_values(node_uname_info{job=“$job”}, instance)
The expression in the gauge is also simple:
(sum by(instance) (irate(node_cpu_seconds_total{instance=“$node”,job=“$job”, mode!=“idle”}[$__rate_interval])) / on(instance) group_left sum by (instance)((irate(node_cpu_seconds_total{instance=“$node”,job=“$job”}[$__rate_interval])))) * 100
- How are you trying to achieve it?
- I enabled “multi-value” for variable $node
- I used the “repeat for” option with the selection “$node”
What happened?
Stopped showing any values (N/a) -
I expected it to show an indication for each node, after using the multi-value and “repeat for $node” -
See first question -
Gauge shows n/a -
Did you follow any online instructions? If so, what is the URL?
nope
