Is there a way to have a single stat that adjust in color with multiple dash boards with thresholds link to it. Currently using influxdb
Thanks.
Thanks.
no there is no such feature
Is there a plugin that supports multi metrics ex. cpu mem disk network
I created an enhanced version of SingleStat called Annunciator (https://grafana.com/plugins/michaeldmoore-annunciator-panel) that does some of what I think you are describing. Not sure about the linking thing though. Check it out and if it looks promising, let me know what you would want to add and I will see about adding it. No promises, but Iām open to good ideas.
Michael Moore
Thank you I will give it a try.
