Same plugin so it is borrowing heavily from the simple-json-datasource, although my datasource.js is different because I’m using websocket, but the rxJS is the same and is working to an extent. In that I am pulling a single data point back using this solution into Grafana and can display that data in a single stat data panel.
But the same code will not trend this single data point in a Graph Panel, does the data have to be presented in a different format for the Graph panel? Or where would I find the source code for the singe an graph panels so I can have a look at it myself.
