Singlestat thresholds using variables
I need the thresholds for the single stat panel to be dynamic. I created a query driven variable which updates on time range changes. This works correctly in titles, etc. But when I use in the threshold box it doesn’t seem to be working correctly. Is this supported? Should it be working?
Update:
After looking around Github I realize this has been an open issue for 5 years… has anyone found a workaround?
Can you post the link to the issue on github?
@allamiro sure - see the thread below, which contains the Github link
https://localhost:3000/t/support-for-name-variable-singlestat-in-thresholds-gauge-options/7434
Unfortunately right now, even though my variables are updating correctly in titles, queries, etc, they don’t update any thresholds (gauges, coloring, etc.). Wish I knew enough to update the panel code myself but it seems to be a bit out of my skillset (I haven’t been able to successfully compile a custom singlestat panel).
