- What Grafana version and what operating system are you using?
Grafana 9, containerized on Ubuntu server.
- What are you trying to achieve?
Receive proper alert over slack channel.
- How are you trying to achieve it?
I have created a connection to our Slack channel, and tested several slack templates.
- What happened?
The notification are not working, they don’t display any data, and if we use the default, the content its illegible
- What did you expect to happen?
Before we upgrade to Grafana latest version, we had a Notification Chanel were we configure the same for slack, now the same is no longer available, and the notifications are complex to be configure.
- Can you copy/paste the configuration(s) that you are having problems with?
Before upgrading, Grafana v8.0.7
After Upgrading, Grafana 9 latest version.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
I didn’t found any errors/issues after upgrading.
- Did you follow any online instructions? If so, what is the URL?
I followed the Grafana documentation to upgrade through docker compose.
