Describe the bug
Querying over all logs from specific namespace, we’re getting error 504 (GATE TIMEOUT) despite increasing timeouts. Our stack is base on helm chart loki-simple-scalable-1.8.5 and we’ are using s3 bucket for storing data.
I’m just wondering about changing that solution to dynamodb instead of s3 bucket or efs volume?
To Reproduce
Steps to reproduce the behavior:
- Started Loki (SHA or version): 2.6.1
- Started Promtail (SHA or version): 2.6.1
- Query:
{namespace="some-namespace"} |=
504``
Expected behavior
Faster querying without 504 error over logs older than 3 days
Environment:
- Infrastructure: K8s
- Deployment tool: helm, loki-simple-scalable-1.8.5
Screenshots, Promtail config, or terminal output
loki:
readinessProbe:
httpGet:
path: /ready
port: http-metrics
initialDelaySeconds: 30
timeoutSeconds: 1
image:
registry: docker.io
repository: grafana/loki
tag: null
pullPolicy: IfNotPresent
podAnnotations: {}
revisionHistoryLimit: 10
podSecurityContext:
fsGroup: 10001
runAsGroup: 10001
runAsNonRoot: true
runAsUser: 10001
containerSecurityContext:
readOnlyRootFilesystem: true
capabilities:
drop:
- ALL
allowPrivilegeEscalation: false
existingSecretForConfig: ""
config: |
{{- if .Values.enterprise.enabled}}
{{- tpl .Values.enterprise.config . }}
{{- else }}
auth_enabled: {{ .Values.loki.auth_enabled }}
{{- end }}
server:
http_listen_port: 3100
grpc_listen_port: 9095
grpc_server_max_recv_msg_size: 15662562
grpc_server_max_send_msg_size: 15662562
http_server_read_timeout: 300s
http_server_write_timeout: 300s
memberlist:
join_members:
- {{ include "loki.name" . }}-memberlist
{{- if .Values.loki.commonConfig}}
common:
{{- toYaml .Values.loki.commonConfig | nindent 2}}
storage:
{{- include "loki.commonStorageConfig" . | nindent 4}}
{{- end}}
limits_config:
enforce_metric_name: false
reject_old_samples: true
reject_old_samples_max_age: 14h
max_cache_freshness_per_query: 10m
split_queries_by_interval: 15m
max_query_length: 0h
max_query_parallelism: 20
{{- with .Values.loki.memcached.chunk_cache }}
{{- if and .enabled .host }}
chunk_store_config:
chunk_cache_config:
memcached:
batch_size: {{ .batch_size }}
parallelism: {{ .parallelism }}
memcached_client:
host: {{ .host }}
service: {{ .service }}
{{- end }}
{{- end }}
{{- if .Values.loki.schemaConfig}}
schema_config:
{{- toYaml .Values.loki.schemaConfig | nindent 2}}
{{- else }}
schema_config:
configs:
store: boltdb-shipper
{{- if eq .Values.loki.storage.type "s3" }}
object_store: s3
{{- else if eq .Values.loki.storage.type "gcs" }}
object_store: gcs
{{- else }}
object_store: filesystem
{{- end }}
schema: v12
index:
prefix: loki_index_
period: 24h
{{- end }}
{{- if or .Values.minio.enabled (eq .Values.loki.storage.type "s3") (eq .Values.loki.storage.type "gcs") }}
ruler:
storage:
{{- include "loki.rulerStorageConfig" . | nindent 4}}
{{- end -}}
{{- with .Values.loki.memcached.results_cache }}
query_range:
match_max_concurrent: false
parallelism: 24
align_queries_with_step: true
cache_results: {{ .enabled }}
results_cache:
cache:
default_validity: {{ .default_validity }}
memcached_client:
host: {{ .host }}
timeout: {{ .timeout }}
{{- end }}
{{- end }}
{{- with .Values.loki.storage_config }}
storage_config:
{{- tpl (. | toYaml) $ | nindent 4 }}
{{- end }}
{{- with .Values.loki.query_scheduler }}
query_scheduler:
max_outstanding_requests_per_tenant: 2048
{{- end }}
common configuration
commonConfig:
path_prefix: /var/loki
replication_factor: 3
storage:
bucketNames:
admin: bucket-logs
chunks: bucket-logs
ruler: bucket-logs
type: s3
s3:
s3: s3://eu-central-1
region: eu-central-1
s3ForcePathStyle: true
insecure: false
local:
chunks_directory: /var/loki/chunks
rules_directory: /var/loki/rules
memcached:
chunk_cache:
enabled: false
host: ""
service: "memcached-client"
batch_size: 256
parallelism: 10
results_cache:
enabled: false
host: ""
timeout: "500ms"
default_validity: "12h"
schemas
schemaConfig: {}
structuredConfig: {}
query_scheduler: {}
storage_config:
hedging:
at: "250ms"
max_per_second: 20
up_to: 3
# Configuration for the write
write:
replicas: 3
image:
registry: null
repository: null
tag: null
priorityClassName: null
podAnnotations: {}
selectorLabels: {}
serviceLabels: {}
extraArgs: []
extraEnv: []
extraEnvFrom:
- secretRef:
extraVolumeMounts: []
extraVolumes: []
resources: {}
read:
replicas: 3
autoscaling:
enabled: false
minReplicas: 1
maxReplicas: 3
targetCPUUtilizationPercentage: 60
targetMemoryUtilizationPercentage:
image:
registry: null
repository: null
tag: null
podAnnotations: {}
selectorLabels: {}
serviceLabels: {}
extraArgs: []
extraEnv: []
extraEnvFrom:
- secretRef:
gateway:
enabled: true
replicas: 1
# -- Enable logging of 2xx and 3xx HTTP requests
verboseLogging: true
