I configured the smtp section of grafana.ini as follows:
#################################### SMTP / Emailing ##########################
[smtp]
enabled = true
host = smtp.gmail.com:465
user = my gmail adress
;If the password contains # or ; you have to wrap it with trippel quotes. Ex “”"#password;"""
password = xxxxxxxxxxxxxx
;cert_file =
;key_file =
;skip_verify = false
from_address = my gmail adress
from_name = xxxxxxx
; EHLO identity in SMTP dialog (defaults to instance_name)
;ehlo_identity = dashboard.example.com
Howoever, when I try to invite new user I have the famous message : SMTP not configured […]
Any idea ?
Thanks for your help.
Regards,
Christophe.
