v9.3.3 on Roxy Linux 8 (Red Hat 8) -
getting the maximum values of each day in Time Series Panel -
Influx DB Query:
from(bucket: "SAJ-GAB1")
|> filter(fn: (r) => r["_measurement"] == "total power load energy")
|> aggregateWindow(every: 1d, fn: max, createEmpty: false)
|> difference()
What happened?
on the 25.12. there is no value
on the 31.12 there are two values with the timestamp 2022-12-31 01:00:00 and 2022-12-31 13:37:53
for each day one value -
"id": 45,
"gridPos": {
"h": 9,
"w": 12,
"x": 12,
"y": 81
"type": "timeseries",
"title": "Energie Bilanz pro Tag: Bezug und EInspeisung",
"transformations": [],
"datasource": {
"uid": "-- Mixed --",
"type": "datasource"
"pluginVersion": "9.3.0-beta1",
"description": "",
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "bars",
"lineInterpolation": "linear",
"barAlignment": 0,
"lineWidth": 1,
"fillOpacity": 35,
"gradientMode": "none",
"spanNulls": false,
"showPoints": "auto",
"pointSize": 5,
"stacking": {
"mode": "none",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "yellow",
"value": null
"color": "blue",
"value": 0
"unit": "watth"
"overrides": []
"options": {
"tooltip": {
"mode": "single",
"sort": "none"
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
"targets": [
"datasource": {
"type": "influxdb",
"uid": "p-3Ac1z4z"
"hide": true,
"query": "from(bucket: \"EM3\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"sensors\")\r\n |> filter(fn: (r) => r[\"_field\"] == \"total\" or r[\"_field\"] == \"total_returned\")\r\n |> filter(fn: (r) => r[\"device\"] == \"house_phase0\" or r[\"device\"] == \"house_phase1\" or r[\"device\"] == \"house_phase2\")\r\n |> aggregateWindow(every: 1d, fn: max, createEmpty: false)\r\n |> difference()",
"refId": "A"
"alias": "WP",
"datasource": {
"type": "influxdb",
"uid": "000000009"
"groupBy": [
"params": [
"1d"
"type": "time"
"params": [
"null"
"type": "fill"
"hide": true,
"measurement": "WP_kWh_Day",
"orderByTime": "ASC",
"policy": "default",
"refId": "B",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "max"
"params": [
"*1000"
"type": "math"
"tags": []
"datasource": {
"type": "influxdb",
"uid": "jDls7qvVz"
"hide": true,
"query": "from(bucket: \"SAJ-GAB1\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"PV 1 today Energy\")\r\n |> aggregateWindow(every: 1d, fn: max, createEmpty: false)\r\n |> yield(name: \"mean\")",
"refId": "C"
"datasource": {
"type": "influxdb",
"uid": "jDls7qvVz"
"hide": false,
"query": "from(bucket: \"SAJ-GAB1\")\r\n |> range(start: v.timeRangeStart, stop: v.timeRangeStop)\r\n |> filter(fn: (r) => r[\"_measurement\"] == \"total power load energy\")\r\n |> aggregateWindow(every: 1d, fn: max, createEmpty: false)\r\n |> difference()",
"refId": "D"
